Transmission Cooler
Old Nov 14, 2018 | 4:29 PM
  #31
Originally Posted by Twscarp
what didn't work on our vans, the Torque app, or the trans temp?
Trans temp. I think you're the first one to actually show it working. I'd like to determine if it comes down to the app, the adapter, or the vehicle.
I don't know the protocol, or what that means.
The "language" that the vehicle system speaks. VPW is the old language, and CAN is the new one. Mine is definitely CAN. Yours (2008) is on the cusp.
Old Nov 14, 2018 | 6:26 PM
  #32
Twscarp's Avatar
Hi, I think I have VPW.
I can’t remember exactly how I got the Trans Temp, but here is the gist of it. Go into Torque Pro app (pretty sure it was in Torque Pro, might be available in Torque also). Go into settings and choose “manage extra PIDS/Sensors”. Then from the three-dot menu, select “add predefined set”. In the resulting list, choose”Pontiac/GM/Opel/Vauxhall”. Then look for Transmission Fluid Temp (GM Method 1), and Transmission Fluid Temp (GM Method 2), try each one. I thought StanVan and Teammuir1 had it too.
Old Nov 14, 2018 | 9:12 PM
  #33
Thanks I will try that out.
Old Nov 20, 2018 | 4:21 PM
  #34
I tried to monitor the ATF temp on my 2013 with my Scangauge II the other day. I entered the Xgauge per the instructions (https://www.scangauge.com/xgauge/gm-...e-exc-allison/). I tried putting '00' and '01' at the end of the TXF and it didn't work. You would think that if it works on an older vehicle, like my 2000 Astro which has the same 4L60E transmission, that it would work on a more modern vehicle. That's too bad.
Did anybody else try with their 2009 or newer vehicle?
Old Nov 21, 2018 | 7:37 AM
  #35
LCAC_Man's Avatar
Email the tech support guys at Scangauge, they are pretty good about getting back with you and helped me on a similar issue. In my case I needed to update the scangauge unit to the most recent software/firmware version.
Old Nov 21, 2018 | 2:04 PM
  #36
I emailed them and they told me to try the xgauge code for allison transmissions.
EDIT: The Allison code didn't work either. Waiting for further feedback from LL.
Old Dec 7, 2018 | 10:25 AM
  #37
Ron6519's Avatar
Found the choices in the, "pids" section. They had three options. The first one got a response, but the gauge didn't materialize on the dashboard. Any clues how to make this happen?
Thanks
Ron
Old Dec 7, 2018 | 11:13 AM
  #38
StanVan's Avatar
15 Year Member
In Torque, you have to chose the type of gauge you want by adding a gauge.
Old Dec 8, 2018 | 10:08 AM
  #39
Ron6519's Avatar
Thanks, I'll give it a shot. It would be nice if these, "apps" would include an operating manual. This is not a simple device where the workings are intuitive.
Old Dec 8, 2018 | 11:30 AM
  #40
StanVan's Avatar
15 Year Member
Try here;
https://torque-bhp.com/
