What is rectangle plug ?
Old Apr 4, 2017 | 9:33 PM
ChevyVanMan's Avatar
Default What is rectangle plug ?
What is this rectangle plug used for ? I don't seem to have the wiring harness but go to 4.11 minutes and he shows the plug which seems to be mounted .
Thank you
Kenny
Old Apr 4, 2017 | 11:47 PM
Artie1's Avatar
None of my vans (and I had like 10 of them) had this. It might be a factory trailering package harness. It also might be something added (although, most likely a leftover) by the conversion company, if they run a universal harness for various trims.
Old Apr 5, 2017 | 8:19 AM
appears to be the body harness wiring connector.
what year, eng, model do you have. the wiring will be different depending on the build. Something will be there. My non tow equipped truck had everything for the 4 pin connector. i had to run wires for the electric brake hook up.
Old Apr 6, 2017 | 8:28 PM
It is a 2016 15 passenger 3 door 3500 LT van. Ordered a hitch and plan on putting a volt meter on the terminals and seeing if it is a trailer plug, when it gets on the rack . Any and all information is appreciated.
Thank both of you for your replies.
Kenny
Old Apr 6, 2017 | 8:29 PM
It is 2wd, 6.0 engine, 6 speed auto..
Thank you
Kenny
Old Apr 9, 2017 | 1:43 PM
if its not under the center of the bumper, try under the spare tire. Some may have a junction block cavity where other harness plug in.
Old Apr 9, 2017 | 4:25 PM
Looked it yesterday and it is a 6 pin and tested for a left turn blinker and appears no power to it.. The wires are about 16 gauge and it does have a plug over it to protect it. Looks like this would work
Dorman Conduct-Tite 85399 - Electrical Socket | O'Reilly Auto Parts
Thank you
Kenny
Old Apr 25, 2017 | 9:32 PM
dberladyn's Avatar
The rectangular plug, above the one he is playing with at 4:11, is the Rear Backup Sensor Connector.
Old Apr 26, 2017 | 4:38 PM
Thank you, and I wonder no more..
Kenny
