02 Express 3500 box van no start
I have an 02 Express 3500 with a 5.7 Vortec that will not start. The fuel pump will not cycle when the key is in the on or crank positions. I can command the fuel pump on via my scan tool, and it will run until commanded off. Looking at the wiring schematic, it appears as if the only thing left would be the PCM, or something in the ignition not supplying a signal to the PCM to command the relay on. Any help will be greatly appreciated
That's kinda what I was leaning towards. Not exactly sure what lights came on normally, my 97 k1500 vortec has check gauges, a battery symbol, and a brake light in addition to the abs that illuminate during the initial key on test. If the ignition switch was bad, I suppose nothing would illuminate?
