12 Windshield Weather Stripping Coming Apart
Old Jul 11, 2022 | 1:02 PM
Homer Morales's Avatar
Question 12 Windshield Weather Stripping Coming Apart
Hey all, the windshield weather stripping has started to come off and I would like some guidance as to how to fix it or replace it if needed. I have attached a picture of it below. Any help would be appreciated! Thanks.
Old Jul 11, 2022 | 2:10 PM
Is it leaking?? If it is not leaking. I would use a good silicone seal and glue the weather stripping back on. If it is leaking I would have it replaced by a windshield shop.
Old Jul 11, 2022 | 6:21 PM
RoadTrip's Avatar
Yes, glass companies stock many different kinds of window moldings. Check with a local shop to buy some, or possibly even install it for you.
Old Jul 12, 2022 | 1:37 AM
Scissors.
Snip snip. It's just cosmetic trim.
weather sealing is provided by the polyurethane adhesive they use to glue the windshield on, so this should have no effect
Old Jul 12, 2022 | 3:05 AM
William Kisselstein's Avatar
They all do this to some degree. Hard to believe GM has never fixed that problem. Probably just cutting the corners would at least let it shrink without pulling off.
Rubber cement likely would stick it back down
Old Jul 12, 2022 | 10:51 AM
Thank you all for the info, I will try to find a good adhesive/sealant if not just tear it off haha
PAChevyOwner
Dec 17, 2019 5:34 PM
lyleapgmc
Apr 4, 2016 7:43 PM
cocodrie55
Oct 1, 2014 4:43 AM
Jessica Turner
Apr 14, 2013 1:11 AM
deanboy560
Colorado
Feb 9, 2008 10:24 AM
