'16 Dome light issue
Old September 11th, 2017, 9:35 PM
  #11
Twscarp's Avatar
Originally Posted by ChevyVanMan
Yes, I was replying to the original poster.. Chevy dropped the ball on that switch, it took me about 2 hrs to figure it out..
Maybe Stanvan will find it now..
I have no idea what StanVan's deal with the switch is, he never said...
IS THE 2008 SWITCH THE SAME AS A 2016 SWITCH??????
Old September 11th, 2017, 11:59 PM
  #12
canucklehead's Avatar
Another thread where we all jump in but need more input from the original poster.....lol
As for the 2008 question, I think the interior/dash upgrade was 2011 or something. GM added that nice little camouflaged switch that no one can find.
He said his light comes on manually, and his switches are fine, but does not say if he is referring specifically to the hard to find override switch.
I say no more till he comes back.
Old September 20th, 2017, 8:43 AM
  #13
StanVan's Avatar
Sorry to have been absent. I've been in the process of moving. And it has been the move from hell. Some of the stuff hasn't moved since 1954, when my Dad put up his shop.
I am well aware of where the switch is. I truly think it has gone bad. I have found another quirk. So, in moving, I had the dome on manually. After the timeout timer shut the dome off, it seems to work, as long as it manually stays on. I could "kick" it back on by depressing the side door switch, which is normal. But then, I close the doors, and the dome goes out, which it shouldn't because it is manually turned on. Then, I can open the drivers door, get in, close the door, and it acts normally. Once I manually turn it off, it goes back to not working with the doors.
BTW, the side door has the only exposed door switch. I believe all the others are built in to the door latches. I don't know if this is relevant, but I did find it interesting.
Old September 27th, 2017, 2:13 PM
  #14
StanVan's Avatar
The plot thickens. I'm in the middle of swapping out the stereo. I have the dash cover off, with all the controls on it disconnected. I sit back and realize I'm bleeding a little, and happen to look up. The damn lights are on. I go and close all but the side door(which has the old style door switch), and then press that switch in. The lights go off. That override switch has to be the culprit.
Opinions?
Old September 27th, 2017, 6:45 PM
  #15
Twscarp's Avatar
Opinions?
Stan, I still don't understand what your original complaint was about the dome lights? Your description today sounds like they are working correctly.
On another note what happened to Teammuir1, he posted 7 days straight, now nothing for 2 days, hope he is OK.
Old September 27th, 2017, 11:44 PM
  #16
StanVan's Avatar
The original complaint was that the dome acts as if the override is active. And as soon as I reassembled the dash, it went back to doing it. It confirms, at least in my mind, that the override switch is bad. It was only working correctly as long as the switch was disconnected.
Teammuir1 and I started texting about his situation. Even though our vans are 10 years apart, we were both swapping out the stereo, so we thought the wiring in mine might shed some light on his issues, but it didn't quite work out that way. He posted today.
Old October 9th, 2017, 4:59 PM
  #17
Teammuir1's Avatar
I feel silly....
I had no Idea you posted a thread Stan...
there may be a few days I cant reply... but like everything else
when I started in something usually something else pops up... lol
Lucky for me I can start and stop working on my Van anytime
I wish.. so I will post an updated pic for the ones that
are interested.. I do have my radio in.. and Stan and I have been
texting from time to time about our projects....
I know my thead BEST UPGRADES.. has really turned into
a Build thread.. lol
Dont mean to Hi Jack your post STAN lol just thought I would
update... for the fellers...
Stereo is in and works great.. but as you can see I am far from
being done... lol
Old November 3rd, 2017, 11:35 AM
  #18
StanVan's Avatar
So I bit the bullet and ordered the switch from Rock. Even though it's under warranty, it was worth the $30.00 to not be without by van for a day. So I put the new one in and the dome lights now work with the doors.
Except now the override doesn't work! I'll take it, but WTF!!!
Old November 3rd, 2017, 11:43 AM
  #19
StanVan's Avatar
And now it works just fine. Maybe I wasn't saying the right cuss words. But it proves I was right, the switch was bad.
Old November 4th, 2017, 3:02 AM
  #20
Teammuir1's Avatar
STAN I am glad it worked out for you and it didnt have to cost
all that much .. your time is valuable to you and if $30.oo
was all then you scored.
at least now if someone had this issue all they would have to
do is search Dome Light Issue.. lol.. well if they think about it .. lol
Quick Reply: '16 Dome light issue
