1988 Chevy G20 Sportvan - Gear Shift Indicator Pointer is broken
same issue with my 89' GMC g2500 vandura , . Couldn't find one so i improvised.... I know this is really corny but you know the little red coffee stir sticks some of them are a little bit more bendable than others and it bends perfectly up into the little gear position box and then I simply pulled it back out and melted it in that same position and then hot glued it 2 the other side and it moves perfectly in little window problem solved that is unless you have your car for show.
ydissac85
Oct 27, 2020 7:44 AM
