1994 G20 dome lights
suddenly don't work. It's a mark III conversion van with an extra fuse block behind the driver's seat. There doesn't seem to be a fuse in the fuse block under the dash for the dome lights. I checked all the fuses in the fuse block behind the seat none of them are blown. None of those slots seam to go to anything important either. I have been doing some restoration work and reinstalled a reading light but I tore it back out but suspect it might be the culprit.
anyone have an idea? Otherwise I will trace the wire that feeds them and connect it directly to the battery.
I got them to work and found the reading light to be the culprit. I disconnected the power from the fuse block behind the seat and reconnected and they work. I turned the reading light on and it tripped something so I disconnected it and moved 2 of it's 3 wires around disconnected and reconnected the rear fuse block and everything works. works.
