1997 GMC SAVANNA 2500 TRANSMISSION
I dont want to bring to the shop and get it flush because they will run other people crap in mine tranny. When you said run it in each gear, doest it me will I have the car witht the pan off and run it real quick. Might be a stupid question. But I'm tired of changing it. It simple since I dont need a jack, just crawl under. Plus the filter is like 20 buck. What is the Capacity of the Torque Converter. Thanks,
the torque converter takes 1 liter i think as for driving it find out at your parts store if you can get a plug kit for it like in the oil pan. you should be able to then when you change the fluid you can just pull the plug and not worry about the filter for 1 or 2 changes. i meant to drive it for a bit to cycle the fluid though the converter.
russellhall63
Feb 13, 2011 1:53 PM
JHPCGA
May 2, 2007 6:56 PM
