2002 Chevy 2500 Exp Van
I have a BU/SIGNAL fuse problem: the BU LAMP/SIGNAL fuse blows every time I turn the ign to Run. I just replaced the Back-up Lamp/Neutral Safety Switch, plugged in both plugs, did not hook up shift cable(?) or (did not)mount BUL/NSS back in place on transmission case, plugged in new fuse, turned on ign and fuse held, started truck, fuse held.
So I get back under van and hook up shift cable and re-attach Back-up Lamp/Neutral Safety Switch to transmission case, turn ign to run, fuse pops???
I cannot figure out what the problem is and do not know what to do next... Can anybody help me resolve this issue???
Thanks for ANY HELP, really frustrated with this...
Luke in OKC
New Question, same issue: is there a possibility the case/mounting bracket(which is metal) for the Back-up/Neutral Safety Switch is grounding out?
Luke in OKC
Last edited by koolhandluke; January 1st, 2016 at 10:56 AM. Reason: more informaiton received
quick update: I have performed the following troubleshooting from fuse box to NSS...
- with the NSS plug connected to NSS
with ohm meter the PINK that runs from fuse box to the NSS rings to ground in the following test: ign OFF in PARK and ign RUN in PARK or REVERSE
- with the NSS plug disconnected from NSS
with ohm meter the PINK that runs from fuse box to the NSS rings to ground in the following test: not at all
- with the NSS plug connected and the BU Light wire cut
with ohm meter the PINK that runs from fuse box to the NSS rings to ground in the following test: ign OFF and ign RUN in PARK
- with the NSS plug disconnected and the BU Light wire cut
...keep in mind the NSS im testing when plugged in is brand new, installed 01/01/2016...
any thoughts or suggestions?
