2002 Chevy 2500 Exp Van/N Safety Switch
can anybody tell me what the 4 pin plug on the Neutral Safety Switch is for?
I found a diagram and schematic for the 7 pin plug
I have spent about an hour on google and cannot find a wire diagram or schematic for this particular plug...
if you could leave a link or any info would help...
(same problem as my original post)
Thanks
Luke in OKC
Thanks
Luke in OKC
yes that is the 4 pin connector...
been workin on this issue for abt 2 hrs today... unplugged the 4 pin connector, put in new fuse, turn truck to run & started, fuse blew...
w 7 pin plugged in adn 4 pin unplugged put ohm meter on side of fuse that feeds the BU/NSS and it toned out to ground??? unplugged the 7 pin connector and it did not ohm to ground??? im not sure if the fuse issue has burned up the BU/NSS or not... starting to be a real headache.....
do u kno how to check DC amperage? Im not sure if I have a meter that will do this... thanks
thank u for all ur help
Luke in OKC
Luke in OKC
yes I replaced the NSS... but when I put it all back together the fuse popped again? now Im not sure if the (new) NSS is burnt up??? this is gettin to be almost more than I can handle... thanks for your help... keep an eye on this thread, Im taking the van back to the alarm shop in the AM...
