2005 Express bulb replacement and other stuff
Hello. I just got this truck and am now starting to see a couple of annoyances. First is the auto headlight feature. I've got it set, but when I drop it in gear I only get running lights. When manually switched to the headlight position, all is fine. New switch? Next is the light on the heat position selector light not working. I'm sure it just a bulb, but not sure how to remove the face plate. I've seen 2 bolts in the recess and 2 more under the dash on the driver side. Is that all of them? Lastly, the speakers in the front door panels are shot. How do I remove the panels for their replacement? Thanks for any help.
You should def get a haynes repair manual. It has all the tips you need, and also lots of info to familiarize you with the truck. Well worth the 25 bucks....
When you pull your speakers, you will find they are an odd size......but I managed to fit 6.5 inch ones in the factory space.....
riverboatman
Nova & Chevy II
October 30th, 2013 7:44 PM
For Sale: 6" off-road lights and other stuff
2fast4you
August 9th, 2009 5:28 PM
dmetcalf
June 18th, 2009 3:35 PM
