2013 Express 6.0L vibration issue
Old Aug 26, 2025 | 4:47 PM
RustboxF700's Avatar
Default 2013 Express 6.0L vibration issue
Hi, I have a 2013 Express 2wd with the 6.0L gas with 150,000 miles on it. It has a vibration that feels like driving over rumble strips intermittently ranging from 40mph to 65mph. It seems to do it more when it has been sitting for a little while. So far I have replaced both front wheel bearings thinking one was possibly getting worn, checked the drive line and all is tight besides a little bit of play in the slip joint, inspected the differential after changed the gear oil, transmission fluid is in good condition, ball joints and tie rods have a little wear but not bad, checked for codes and it has none, rotated the tires and that made no difference, motor mounts seem to be in good condition. Not really sure what to check next and I don't want to throw parts at it, any help would be much appreciated.
Old Aug 26, 2025 | 8:04 PM
Triaged's Avatar
How about the idler arm bracket? Nobody (except me) ever greases them. I got the extension hose to make greasing it easier. https://www.rockauto.com/en/moreinfo...08860&pt=13418
Old Aug 27, 2025 | 9:35 AM
Which idler arm bracket do you mean? If you mean for the steering this has a rack and pinion for the steering
namkapow
Oct 11, 2024 1:43 PM
Dno36
Jan 25, 2022 9:43 AM
VanKo
Jul 29, 2020 8:41 AM
Southern Comfort
2007 - 2013 (GMT900)
May 22, 2019 7:44 PM
Jesse Via
Apr 28, 2018 5:11 AM
