2018 Chevy Express van violent shake
Old February 25th, 2021 | 10:34 AM
flash0513's Avatar
Default 2018 Chevy Express van violent shake
Holy Crap!!!... I have a 2018 Chevy Express 2500 Explorer van and was on the highway driving approximately 55-65 MPH and when I applied the brakes to slow down for EZ Pass, the whole van started to shake violently and uncontrollably. Once I let my foot off the brake, it stopped shaking. This is the first time this has happend as I drove the van the day before with no issues. It has been doing it ever since. I have it parked now for obvious reasons.....ANY IDEAS? Made appointment with Chevy, but not until Monday.
Edit Quote
Old February 25th, 2021 | 11:04 AM
That's usually a sign of warped brake rotors
The following 2 users liked this post by mountainmanjoe:
flash0513 (February 25th, 2021), Sean Rothar (February 26th, 2021)
Old February 25th, 2021 | 8:30 PM
William Kisselstein's Avatar
Does the steering wheel move side to side a bit as it shakes? Warped rotors.
You can drive it with care since it has anti-lock brakes it will counteract if a wheel should grab and lock up.
One of my G-vans the rotors were fine until they got hot and then they would warp, I drove down this steep hill in Virginia that way and the wheel was literally moving back and forth an inch or more at the bottom.
Old February 26th, 2021 | 8:13 AM
hanky's Avatar
If there is anything loose in the steering or suspension, applying the brakes can bring out a problem that is not apparent when going straight ahead.
A thorough inspection by someone who knows what to check is in order here.
Old March 3rd, 2021 | 7:02 PM
SteveROntario's Avatar
Semi-metallic brake pads are supposed to be better than ceramic brake pads on these vans. Apparently ceramic pads are not well suited for this application and the shaking is the end result.
gulfcoastjoe
May 29th, 2008 6:21 PM
gulfcoastjoe
May 29th, 2008 6:19 PM
gulfcoastjoe
Camaro
May 29th, 2008 6:18 PM
civicsir
HHR
February 12th, 2008 11:46 AM
Quick Reply: 2018 Chevy Express van violent shake
