88 TBI replacement has different TPS connector.
I'm installing a replacement throttle body on a 1988 G20 305, It seems to be a good match except the connector for the tps is different.
If I swap out the male connector will the tps function the same as the old one ?
Also, the lower throttle cable connector is different. any issues with adapting that to fit ?
Thanks in advance.
Thanks in advance.
