95 G30 van seat needed
Hi all,
I recently got a '95 30HD flipnose Van that only came with the driver's seat in the cabin. I need a passenger seat but have had no luck calling any junkyards I could find within a 30 mile radius. I can't find any offers on eBay or anywhere else online so I figured I'd try here. Has anyone had any luck mounting a seat from an alternate vehicle in their van? The mounting points are spaced 10.5' in apart in width and 10.75' in length.
Really appreciate your input or any offers if you are selling. Thanks!
Does it have the seat base? You can mount 97-up seats on the metal base, width is the same, tracks are the same on the manual seat, a power track is a couple inches longer.
Without the base it may be an issue as the newer seats are not as tall.
The other option is to hit a conversion van. The seats used in those typically have multiple bolt patterns so the seat assembly itself will bolt in regardless if it was in a Dodge, Ford, or Chevy. You will still need tracks, but the 97-02 vans appear to use the same tracks as 92-95.
kychop
December 2nd, 2013 6:44 PM
iaconsultants
February 4th, 2011 2:18 PM
boat4rob
November 10th, 2009 7:10 AM
