97 EXPRESS Having trouble starting Please Help
I have a 97 Chevy Express 1500, 4.3L Engines, V6. I have had this van for a long time and she's been good to me. However, she's been acting up lately and not starting up when I turn her on right away. ( kind of like a woman) ![Roll Eyes (Sarcastic)](https://chevroletforum.com/forum/images/smilies/rolleyes.gif)
Also, not get a lot of power when I press down on the gas either.
Anyways, I hooked her up to a fault code tool and here are the fault codes she came up with.
P0102: Mass or Volume Air flow Circuit Low Input
P0300: Random/Multiple Cylinder Misfire Detected
P0441: Evaporative Emission Control System Incorrect Purge Flow
Can anyone please help me get her fixed? I just need to be pointed in the right direction and any help would be greatly appreciated.
Thank you in advance.
google those codes. That will point you in the direction of what needs changing.
p01012 bad MAF sensor. mass airflow
p0300 random misfire. check your cap, rotor, and plugs and wires. ( cap gets corroded on pins)
p0441 evap purge solenoid bad.
rockclone
February 1st, 2011 1:36 PM
