99 Astro Van Noises
99 Astro Van Noises
Specs:
v6 vortec
rwd
1999
230k miles
2 days ago we blew a return trans cooler line. Got it towed via a rollback tow truck to a local mechanic where they repaired the hose(Spliced in a new piece). Now we are getting the following symptoms which weren't even showing the slightest bit prior to the trans cooler line blowing.
- Check gages light
- 2-5 idle oil pressure - 15-20 moving /// Before trans cooler line failure we were getting 20 idle oil pressure and 40 moving
- Hesitation on staying running when coming to a stop
- Ive isolated the noise with a long tube to be coming from where the starter bolts to the motor
Things ive tried:
Marvel Mystery Oil in the oil
Seafoam in the vacuum intake line
Oil Filter
And again even with 232k miles we were not having any symptoms from the trans / motor at all. Ran like it would brand new back in 99.
Any ideas?
v6 vortec
rwd
1999
230k miles
- Check gages light
Things ive tried:
Oil Filter
Any ideas?
Oil looks clean. Just bought it about a few weeks ago when our rings gave out on our 94 f150. Still trying to figure out how to upload this video.
Also after putting that MMO and Seafoam in and went to start it this morning to take this video it was holding 40 pounds for oil pressure until I took it for a spin around the block. It dropped to the 20 pounds after it warmed up while not moving in gear. With 35-40 while moving. Still have the hesitation like it wants to stall out when I go to stop..
When I get this uploaded you will defiantly be able to tell its coming between the trans and motor right at the starter area.
From what im seeing is it could be a flexplate crack? Still rather upload this and let yall decide. Thank you
Last edited by LewisFamily8719; May 9th, 2018 at 10:23 AM. Reason: Last line input
And as I said above I used about a 3ft piece of garden hose and this noise is directly coming where the trans bolts onto the motor.
*Edited for more speicific* - Put hose to front facing side against trans at trans / motor.
I had an '74 P20 step van with a 350 V8 in it. It had a similar noise. A GM line mechanic took literally 5 seconds of it to hear that the torque converter was loose on the flywheel. Granted it's been "mumblemumble' years ago, It sounds similar to me.
You are in the full-size van section. I'm not trying to be rude, but you may get better help in the Astro section:
https://chevroletforum.com/forum/astro-28/
I can also recommend astrosafarivans.org
