99 chevy express 1500 starting issue all imput apperciated
i just bought a 99 chevy express 1500 series work van has the 6 cylinder in it. for some reason when its cold it will not start i then spray a little startin fluid in the intake and then it will start rite up no problem then after i run it for a few it will start back up with a problem. anyone have a problem like this? i have been searching around have not found any one to have this problem all imput is really apperciated as this is my only form of transportation.
There are several connector plugs in the wiring for the fuel pump. Open the wiring plug located at the front of the fuel tank. On close inspection you may find one of the terminals looks darker and has melted plastic around it. This is the terminal for the wire that operates the fuel pump. I ran a jumper line around the connector and solved my problem.
Maybe a tune up? New plugs wires and air filter? Those things are never a waste of money if its reasonably due for them and you do it yourself. Might check the fuel pressure too. Could be the fuel filter is restricted. Also, run a can of good injector cleaner through it if you haven't already.
Next time you do a cold start turn on the key and wait 5 seconds without cranking the engine. Then turn the key off, wait 5 to 10 seconds and then turn the key on again for 5 seconds then crank it and see it it starts any easier. Basically you are pumping up the fuel delivery system really good before you crank it. If this helps, it could be pointing to a fuel delivery issue
You can pick up a fuel pressure kit reasonably cheap at an import tool company like Harbor Freight or JC Whitney.
Chevrolet Forum News
July 15th, 2014 4:48 PM
Johnny Crab
November 3rd, 2013 7:18 PM
ZlockoutMZ
March 12th, 2013 10:45 PM
