ABS Brake Bleed
ABS Brake Bleed
Do I need a scanner to bleed the brakes on a 2001 GMC Savanna 2500 series cargo van? I replaced all the brake lines on the van. Bled the master cylinder as per the manual. Can't seem to bleed the brakes. Hardly any fluid comes out.
If scanner is needed, appreciate the make and model of the unit needed.
I have a Blue Driver and an ELM-327.
Thanks
Ron
Thanks
Ron
steven windsor (November 17th, 2019)
No, you shouldn't need an scanner. I don't think Blue driver has the capability. I think only the $1,000+ tools do that.
I found the Audel Max Pro has the ability to interact and bleed the ABS system. Ebay@ $180.00.
I still don't know why the system can't be bled if you don't need a scanner for the ABS component.
Automated bleed Procedure
Thanks
Ron
Thanks
Ron
Johnny bhoy (November 26th, 2023)
Steve, thanks for the information. I'll get the Audel scanner this week to "bleed the ABS module. If that doesn't work, I'll bring it to the mechanic to have him bleed the ABS with his scanner.
Have to do a relearn on the crankshaft sensor anyway.
mountainmanjoe (November 26th, 2023)
So zero chance of gravity bleed on these?
The pre-4WAL G-vans are easy to bleed, slight incline and the master is high enough it flows pretty good. Maybe pump it just a tad to get it moving and it would flow fairly well, to the point I'd run the fluid through a couple times before buttoning it up.
After losing the fluid in the tank on the 2500 I seem to have some air in mine, and I think I'm going to see if Monro will still bleed for a flat fee and have them do it. I'm afraid of breaking bleeder screws though. I have a set of wheel cylinders here, but that means more labor and probably at least the lines across the rear axle.
But I suspect I may need shoes anyways, just have been too lazy/busy to try and take a drum off and look. That alone sometimes brings the pedal back for whatever reason, moving the wheel cylinder pistons in.
Autel Maxicheck Pro will not do the job. Looking for another scanner.
Gave up the ghost and brought it to a mechanic. Proper scanner not worth the expense.
