AC compressor leak
Old May 3rd, 2019, 7:40 PM
  #11
Karlson's Avatar
Originally Posted by tech2
not worth it for a shop to do this as any problems would be a free repair. but if your doing it for yourself...$25 and some time is all you are out.
Thatīs what Iīm thinking too. I donīt mind at all doing some work on my vehicles since it is my hobby. Over here (Sweden) a new or rebuilt compressor would cost me about $300-600 so the $25 repair is worth a try. Leave the Van to a repair shop to do everything would probably be $1000 or more.
No problem, Karlson. I wish you well in your task replacing this A/C seal.
Thanks. I will in any case also replace the receiver drier, fill with new compressor oil and perform a vacuum pull before recharging with R134. I have my own vacuum pump and hose/gauge set to do that.
Old May 13th, 2019, 9:55 PM
  #12
loopedr1's Avatar
a new compressor in the US is pretty cheap....i wounder how much it would cost to ship you one......
https://www.rockauto.com/en/catalog/...ompressor,6628
Old May 13th, 2019, 11:42 PM
  #13
for me in Canada...cheaper just to buy here...shipping, exchange rate and border brokerage fees (if you ship ups) kills it. You guys get everything cheap! We get screwed!
Old May 14th, 2019, 12:18 PM
  #14
Karlson's Avatar
I use to buy quite a lot of parts from rockauto and looked at an ACDelco compressor in the link you provided. There is an ACDelco that costs about $200 and it will end up at a total of about $300 with shipping and import taxes. It is not that bad but I try to keep this Van at low budget
Old August 11th, 2019, 1:37 PM
  #15
Karlson's Avatar
Finally got the time to do this.
Took the compressor out of the van.
I had a moped flywheel puller with the correct treads, think it is M19 that fitted perfectly to the treads in the magnetic clutch.
Pulled that off. The pulley and bearing were attached with snap rings so no problem to get them off.
There were six long bolts holding the housing together, took them out.
The housing consists of three pieces which needed to be gently hammered apart.
Once apart it was pretty obvious why it was leaking, the mating surfaces for the three big o-rings were very corroded.
Cleaned all the surfaces were the o-rings should seal up to.
Installed new o-rings and put it back together.
Filled the compressor with 8 fl.oz peg 150 oil.
Also changed the receiver/drier to a new one, as well as the orifice tube.
Put the complete system together and performed a vacuum pull, I did let it pull for about an hour.
Then let it sit for another hour to check the Vaccum was stable and didnīt change. (which it didnīt)
After that, I started the engine and turned the AC and fan on full.
Filled it with 4 12 fl.oz cans of R134.
It now blows really cold air out of the wents and everything seems to work just fine.
Didnīt take that many pics during the process but I attach some pics I took.
Old August 11th, 2019, 8:36 PM
  #16
great fix
Old August 12th, 2019, 2:33 PM
  #17
Karlson's Avatar
great fix
Thanks tech2.
As you mentioned, being outside the US, parts from US could be really expensive to get so doing as much as you possibly can by yourself will keep costs down.
