Adding a Tow Hitch
#11
Ok, So I finally just got my hitch mounted. I am disappointed with CURT. I think the hitch is a good design, I like it however they obviously never tested what they are selling. All 8 frame holes on my Savana are 1/2". All 6 holes on the CURT hitch are 1/2". However, CURT supplies and instructs you to use four 1/2" (3/4 head) bolts on the rear four holes and two 9/16" (7/8") head on the forward two holes.
See the problem?
I could have just found two more smaller carriage bolts, but then that would actually have been a problem as you still need a special plate for those bolts. Then, the real concern... they specify 7/8" bolts on the forward holes for a reason. I imagine this is all certified, the hitch is rated right? So if you use smaller bolts and you have a problem hauling a 7000lb trailer, you are legally screwed. Not CURT, the supplier. Safety and legal responsibility was my main concern.
I had to bother a friend to use his machine shop to widen the hitch holes to accept a 9/16" bolt, and I had to drill the two forward holes on the frame larger, from 1/2" to 9/16". I don't fault CURT at all for having to drill GM's frame, that's actually easy, but having to drill out their own hitch to use the very bolts they supply is bad. Without a machine shop I would have had a hell of a time. And now for me, my shiny new hitch is all scratched up from being installed, reinstalled, reinstalled again and all the manhandling. Disappointing.
But it's now in and that makes me happy. Just wanted to share the experience for others.
See the problem?
#12
I recently purchased the curt tow hitch with the harness that connects to the tail light harness, but seems like the van is already wired and has a plug that is in the back bumper. Does anyone know where I can get the harness that connects to that one into the 4 pin?
#14
I would try Etrailer, Ebay and the dealership if all else failed. Is that plug on the very rear of the left frame rail? I'm going to look again to see if I don't have it, but I am sure I don't and in the back of my mind I know I don't. I was just looking at my van trying to work up the initiative to begin the wiring today. Now the weather is ok and I have the time, I don't have the drive for it.
#15
#16
That's not for a trailer harness. That plug is for the Parking Sensors on the rear bumper. I have that option. Here you can see the six conductor harness that plugs into it, it routes to each sensor on the bumper.
Back to plan one for you.
#17
#19
