Anyone have a plow on their Express van?
Old Dec 25, 2016 | 11:38 PM
  #11
we set up a old heavy plow unit on a 2500 truck for plowing the dealership lot...it dropped the front end so drastically it changed the toe setting of the front tires....we had to raise the torsion bars and send it for an alignment.
Old Dec 25, 2016 | 11:45 PM
  #12
expressvanman's Avatar
that's pretty much the norm for any truck you hang a full size plow on. A full size plow weighs about 800 pounds. You always have to realign if you're going to leave it on. I literally install mine when it snows do my stuff and pull back into my shop over the drains and rip it off
Old Dec 25, 2016 | 11:47 PM
  #13
no, they use both. some use the same set-up as the pick ups...I know, I worked for a chevy dealer for 10 years and have seen them.
not anymore. The new body is all coil springs. 2500 or 3500. There are no torsion bars
Old Dec 28, 2016 | 8:06 AM
  #14
have not seen the new bodystyle. last time i was at gm it was 2015.
Old Apr 5, 2025 | 5:33 PM
  #15
mikeinminneapolismn's Avatar
Default 2004 Express
Plowed better than most trucks ever did
Old Apr 21, 2025 | 3:56 AM
  #16
timn's Avatar
I’ve seen a few Express vans outfitted with plows, but it really comes down to reinforcing the front end and making sure the transmission can handle the extra strain. Most setups I’ve come across require upgraded suspension and cooling systems to deal with the added weight and constant stop-start motion. It’s not common, but definitely doable with the right modifications.
Old May 12, 2025 | 8:42 AM
  #17
Tell me about your front end work on this please? Aside from fabricating a way to mount the plow, what did you do to the front suspension?
lovevans
39
Jan 8, 2026 6:05 PM
lovevans
35
Sep 25, 2023 10:15 PM
sparkync
10
Jan 1, 2023 5:53 AM
cat320
15
May 12, 2014 10:09 PM
BKnaus
May 30, 2012 9:50 AM
