Anyone having problems seeing correctly with split view side mirrors?
#21
I wish now I would have taken pics of the doors with the panels off..
I would have liked to have gone back myself.. and looked at them...
would have given everyone a clear understanding...as to what
to expect behind them... I just wouldnt have thought ....I would use those
pictures...
I do plan on taking my door panels back off again ...but that could be
awhile now that the cold has set in..... from my best recolection
I had the wires in the door for the power mirrors I have electric door locks
and I know it was all together.. wires all together.
pictures...
#24
Power to the replacement mirrors
i am also converting to power/heated mirrors. i have the new switch installed and there seems to be no power coming from the switch to the connector when the different directions are selected. Do i have to put a fuse in the fuse box i haven't had a chance to look if there is one in there for the power mirror switch..
Thanks
Thanks
#25
Thanks
Thanks
#27
You do not really need the harness. You can look up your van on GM Upfitters, find the reference to the terminals required, order them from a large electronics distributor like Mouser.com, and just use common wire of any colour. I actually had an extra set of those wires that I was going to sell, but I think I used them. If you want to buy a harness, search your local Craigslist for a Savanna/Express being parted out, or just search for a body harness on ebay. You have to kind of be really luck to find one. For me it was just luck. Not once, but twice. I bought the whole interior wire harness - for everything.
#28
Thanks
You were exactly right, the male pins are missing out of the harness connector...Im thinking about cutting the connectors out of the harnesses in the doors and just wiring it myself IF I cant easily find a donor van. Will any changes need to be made on the heater part to the mirror besides changing the hvac control head and possibly adding a relay under the seat? again tks
#29
Just check your fuse box to see if the Relay and the Fuse are there. If they are not, take a look to see if the metal contact pins are there for the Relay and Fuse to plug into.
EDIT
If you are not going to keep it factory for the poor sap who buys it after you, or the poor mechanic who has to work on it, or even for your own sanity, then I suppose you can just hack the power supply for the mirrors too. I did not have to add the wires to the factory defrost button, they were there in my truck. I have AC and no rear HVAC for factory options.
#30
fuse for the mirrors is installed and hot. the fuse and relay for the heater is there but no voltage going to the fuse. Im going to get the 12v from the mirror fuse to the mirrors, get a hot wire from the turn signal to the mirror connector R&L, and run wires to the right mirror connector. After that I will have to see where the voltage disappears on the heater fuse in the fuse box. More hunting to do....That upfitter manual you sent is very informative Thanks!
