Aux Battery Location for 2014 Express
Old January 17th, 2019, 11:01 PM
  #11
haznavy's Avatar
I have found very little reference to the auxiliary battery in the 2015 upfitters manuals; guess I need to do a deeper dive.
Old January 18th, 2019, 1:44 AM
  #12
I use a SurePower 1314 battery separator. I think it's really good bang for the buck.
If the battery mounted to your frame is a starting battery, you are going to finish it off pretty quickly with your intended application.
The 2013 upfitter manual has a few schematics for aux battery with isolation.
Old January 18th, 2019, 11:56 AM
  #13
haznavy's Avatar
Great information, thank you!
Old January 20th, 2019, 12:51 PM
  #14
dberladyn's Avatar
GM has done different things in different years, different wiring options. Sometimes the auxiliary battery is isolation, sometimes it is a 24/7 parallel setup. I think the key is understanding differences of each and making the right decision for your own needs, including whether or not you wire as the factory does or not. I am not sold on an schematic or parts until I actually go and purchase them. Even though I do have a relay here that would likely suffice, in the back of my mind I am subject to ordering this part for it's heavy duty aspect and it the fact that it provides flexibility in wiring up tell-tales. It provide electrical contacts to tell you when the battery is engaged and when the battery is not engaged. I am sure this can handle the amperage of a large group of batteries connected in parallel. In my grand overkill plans, I am up to four auxiliary batteries that will likely never get installed.
(Correction, I thought this was listed at 1000amps. Maybe there is a second similar model. 500 amps still more than enough.)
tsmomoney
October 8th, 2015 9:04 AM
LeeHamilton
March 31st, 2012 2:26 PM
in2pro
May 29th, 2008 11:22 AM
kendog47
October 14th, 2007 5:03 AM
kendog47
October 11th, 2007 9:08 AM
Quick Reply: Aux Battery Location for 2014 Express
