Backup (reverse light UK) Light not working
OK
so just got my Chevy G30 so be prepared for alot of stupid questions.
I went out this morning to fit revers parking sensors, could i find the revers light.....NO.
took the passenger side lights out the houseing so i could see them come on inside the van. Put the van in revers expecting to see one of these light - nothing
So my question is where is the reverse light and why isnt it coming on. The back of the van looks like this
http://sdrv.ms/MIEDdX
Ok, the reverse lights are not working (both)? If you haven't checked the fuse, thats the first thing to do. Fuse is good, check bulbs. Bulbs good, probably the switch on the steering column.
all fuses are good, that was my first port of call. my rear lap units consist of two bulbs each, top bulb (clear) is brake/running light(red lense outside), bottom bulb (yellow) is indicators (clear lense outside) Is the reverse light one of these (bottom buld)?
if so then it lights up yellow when reversing????
The bottom lenses as I see from your image is backup/reverse lights. Nothing else should turn on withouht it beibf key on, and in reverse (gear shift) Brake lights are independant, BTW Do they work? Can you tell me if you have all tail lights, brake lights working?
"The bottom lenses as I see from your image is backup/reverse lights" -but the bulb is yellow and only seems to operate for the flashers.
"The bottom lenses as I see from your image is backup/reverse lights" - with the exception of the backup lights all tail lights WERE working before i took the unit apart to install reverse parking. no that sides brake light wont come on, but it dose light up for running lights
"Scratching head""
"Scratching head""
"Scratching head""
"Scratching head""
The back of my van is like this
![Name: van1.jpg
Size: 24.8 KB](https://chevroletforum.com/forum/attachments/express-savana-g-series-vans-30/11776d1501529258-backup-reverse-light-uk-light-not-working-van1.jpg)
A) is the running lights and when you press the brake it gets brighter (Clear Buld)
B) is just running lights im sure tho not checked
C) is the indicators the lense is clear but the bulb is orange so you see the indicators in operation.
dont worry about the brake not working i can trace that and fix it. Just need to know where the reverse light is. Was talking to a freaind and he said it may not have one, is this possible before i start taking the vanappart?
![Name: van1.jpg
![](http://i1057.photobucket.com/albums/t385/yeti_71/van1.jpg)
B is clearance/running light
C is backup/reverse light
There should not be any orange/yellow bulbs on the back of your van. C should be a clear single filiment bulb.
You stated earlier that you installed a reverse kit? What did you have, and do with it?
