a/c cooling issue
Old August 24th, 2019, 9:56 AM
  #11
Originally Posted by Syncman
Sorry, that's a 2004
I looked up service info your build. I believe for your model year; it uses a variable displacement compressor; meaning the compressor does not cycle off...(verify this). the compressor varies its output to stop freeze up. the method to check operation is to monitor high and low side pressures when the problem occurs. if the high side is normal and the low side is low( below 35 psi) the problem is most likely a bad low pressure switch or compressor. start with the switch its cheap.
Old October 14th, 2021, 9:44 AM
  #12
AveryMolly's Avatar
The same issue here. When I sought help from specialists, I was lucky enough to find decent professionals who sorted out the problem. They replaced all the necessary parts and instructed me on how to continue using the air conditioner. I think this is the right approach to working on an appliance that needs repair. I think you can also find help at https://www.marvellous.sg/aircon-chemical-wash/. It's really effective in making the air conditioner work.
Cableguy216
2007 - 2013 (GMT900)
August 2nd, 2019 2:07 PM
terrymanis1
August 29th, 2014 9:03 AM
Mudrucker
August 28th, 2014 10:24 AM
Chevy45224
May 23rd, 2013 11:27 PM
ppg
April 29th, 2013 6:29 AM
Quick Reply: a/c cooling issue
