Chevy G30 Sportvan Issues
I have a 1995 Chevy G30 Extended Sportvan. I have a couple of issues that I've noted and I'm wondering if they are all connected or separate things to deal with.
1. Possible Rear Differential Issue?
I was walking out to the van today and noticed that it looked as if there has been a leak in the rear. From what I've been able to find out online using Google is I think that is the rear differential. I saw a photo that looked pretty much just like mine and it was information about changing the seals & bears of the rear axle case. It its not the same I apologize as I'm not really a car guy. I have photos:
Driver's Side:
Passenger's Side:
2. I've noticed when I'm driving there is a whirling noise as driving. Seems to have a different tone depending upon the speed I drive. I read that this maybe a part of the above item but I have no idea.
3. When driving along at probably more than 45 MPH or so the van does not seem to kick into passing gear. It will kick into the first passing gear at a lower rate of speed, but when it comes to the normal speed it should kick in, it kinda revs for lack of a better term. It just does not kick into passing gear and readjust as it should.
4. After my starter issues the van sat for some time. When I started driving it this last month I noticed that the ABS brakes & parking brake lights were on and stayed that way. At first there was no problem, but then after a couple of small trips the brakes have gotten really soft at one point they failed (which was scary). I parked it after that. My thought was that since it had been sitting for awhile that it may need brake fluid. So I checked the brake fluid reservoir and it was almost full. I topped it off a little bit, but I'm kinda scared to drive it anywhere as I suspect I will have the same issue with the brakes. Would I also need to add brake fluid to the master cylinder? I did not because I did not know if that would cause a problem or not.
Any help at all you can give me would be great.
Driver's Side:
Passenger's Side:
It looks like a minor differential cover leak. Open the filler plug and check the level. Your manual should state what it should be (between 0 and 1cm below the fill hole depending on your model I think). If it's up full, and it's not dripping on your driveway, then don't worry and keep driving it. If it's low, then top it up, and snug up the bolts a bit more. If you leaking badly and you haven't changed it in a while or it's really contaminated, then change the fluid and gasket.
2.
Do step one first. Could be a lot of things. There's not enough information. Is it coming from the front/rear? Effect of turning left/right? Accelerating/decelerating? All gears? All speeds?
3.
I don't understand. What are you doing? Depressing the accelerator? So you're saying it's not down shifting and the van is actually slowing down?? What is not readjusting? Have you checked the transmission fluid?
4.
Brake fluid level normally goes down as the pads wear down. Don't top up unless it's really low, otherwise you'll have an overflow next time you change the pads. The master cylinder is fed directly from THAT reservoir.
If your brakes failed completely then some brake component has bit the dust. A failed caliper, MC, or worn out rubber brake lines etc. A mechanic will need to diagnose your system. Since you're not a car guy, I don't recommend working on your brakes as a jumping off point.
2.
3.
4.
2.
3.
4.
Brake fluid level does not go down in a healthy system. It doesn't matter if it's been sitting 8 months or 8 years.
It sounds like your van needs a road worthiness assessment from somebody mechanical.
William Kisselstein
November 24th, 2019 10:34 PM
oneStickySilverado
14
December 15th, 2010 2:40 PM
