control module - gm (19368155) PROBLEM
Hi guys i have a 2005 express 3500 passenger van and the lights for the stabilitrac and the abs are coming up so after checking i come to the conclusion it is the abs control module and no body seem to have it i check all mayor retailers and some online and in some websites is listed as discontinued i find the one whit no JL4 (control active brake ) every where so my question is can i use one of those and live whit out the dran stabilitrac or it have to be the module that have that and if so why is discontinued and where can i found one?
how do you know it's the module itself that failed?
Did you use a diagnostic scanner to read out the fault codes?
Thanks for the tip i going to contact Cardone hope they can fix it , i take the truck to a mechanic when the lights starting to come up intermittent and he tell us it was the abs module but i did not ask him what codes he got this was over four months ago at the time i was not driving much the van but is time to get it fix it also started to have more issues besides the abs , stabilitrac and brake light on now also the pedal feel sponge some times and also started to drain the battery at night i finally went to the dealer to see about getting a new abs module and they confirm they discontinued the module so only option is repair or get one from a junk yard , if somebody knows more places to get it repair or someone selling that module i appreciated the help i already call local yunk yards whit no luck.
MMVIII_Silverado
January 20th, 2014 2:48 PM
