Door Lock Module Location Chev Express
Hello , does anyone know where the unlock module is located?. I just got a new to me company van without locks. I purchased a door lock kit to install. However I want to use the existing wiring to the actuators. I have scanned the net and here and had no luck locating a diagram where I can install my control.
Any help would be appreciated , Pax
on power lock equipped vans the locks are actuated through 2 relays controlled directly by the bcm. Unlike the trucks which have separate door modules.
I'd be interested in knowing if the power lock wiring harness is present on a manual lock van? what year is the van?
Hi , yes the wiring is there and usually is in many vehicles.I wanted to know the location as I thought I could install the wireless module so i could use the existing wiring and not need to run new wire as the van is already wired. The van is a 2010 Express with DIC , thanks , Pax
kanyons
February 1st, 2022 3:11 AM
macsnjets
July 6th, 2012 5:48 PM
joelwolverine
August 18th, 2008 2:35 PM
