Front jounce bumpers
Old June 30th, 2018, 11:32 AM
Photogdave's Avatar
Default Front jounce bumpers
Has anyone ever noticed on the 3500 vans the controls are riding on the bumpers? To me this would create a stiff ride in front. Any reason known as to why they sit on them all the time? It should be the springs job to hold vehicle up, not the bumpers. The shocks control the spring action.
Ive always thought my van needed more compression travel to absorb things but now I see why it doesn't. I thought about removing then and driving to see if t helps any. I know they need to be there for hard sudden unseen hits, but like most vehicles here should be clearance there and only come in contact with bumper in extreme cases
Old June 30th, 2018, 12:29 PM
Twscarp's Avatar
What year and motor. Do you mean the control arms are riding on the bumpers? Doesn't seem possible unless the coil spring is broke. How about a picture?
Old June 30th, 2018, 12:34 PM
Photogdave's Avatar
2006 3500 with 6.0
155k miles.
yes the lower control arms are always touching the bumpers
Not compressing them, but touch. So any compression movement would be inhibited by the bumpers.
I'll got grab a pic now
Old June 30th, 2018, 12:38 PM
you got torsion bars or coil springs? If someone cranked the tb up...that would do it.
Old June 30th, 2018, 12:45 PM
Photogdave's Avatar
You can see deteriation of the bunker from being used/hit so much
Here you can see there's very little distance between control arm and bumper. Doesn't allow for much compression action before inhibited by bumper
No it's coil spring.
Old June 30th, 2018, 1:03 PM
Twscarp's Avatar
It might be normal, here is my 2008 Express 1500 4.3 with 224k. Mine seems to ride just fine.
Attached Thumbnails Front jounce bumpers-20180630_135246.jpg   Front jounce bumpers-20180630_135322.jpg
Old June 30th, 2018, 1:09 PM
Photogdave's Avatar
Yeah I notice they all sit like this. Just seems wrong. When all other vehicle have more clearance. I might take them off and see if it improves ride. Might not make a hill of beans difference. I know it needs shocks in front, it bounces a good bit. But it's the initial hit. But it might be the huge springs in it that comes with 3500
Old June 30th, 2018, 1:42 PM
StanVan's Avatar
With 12 years and 155k on it, the springs may be sagging a bit. I don't know how hard those miles/years were, but it's a thought.
And when you do the shocks, consider these;
https://www.ebay.com/itm/NEW-2015-GM...649&rmvSB=true
They were suggested by a member here, and since then, a couple of us have gotten them. I haven't installed the back ones yet, but the front ones made a huge difference.
Old June 30th, 2018, 1:45 PM
StanVan's Avatar
Ooh, a thought. There is some spring in the shocks, which may be why yours is sitting on the bumpers, if the shocks have lost that spring.
Old June 30th, 2018, 1:46 PM
Photogdave's Avatar
thats great. I'll do those, thank you. They look buildable which would be good, I do work at a suspension shop.
what was the difference felt with these?
