G20 Van need help
#11
Gmstores where?
Good sources for parts are:
rockauto.com
summitracing.com
amazon.com
lmctruck.com
They will all ship to Europe.
And ofcourse Ebay.
If you are going to change the timing chain I assume you are going to use a kit with chain and sprockets. It is a good idea to change the harmonic balancer at the same time as it is probably worn also.
Be aware that you need a special pulling tool to pull and install the harmonic balancer. (correct me if I am wrong)
rockauto.com
summitracing.com
amazon.com
lmctruck.com
And ofcourse Ebay.
#12
Gmstores where?
rockauto.com
summitracing.com
amazon.com
lmctruck.com
And ofcourse Ebay.
rockauto.com
summitracing.com
amazon.com
lmctruck.com
And ofcourse Ebay.
Summit is more for racing and search for stock parts. Then I took a look but they don't have all.
Rockauto has all but the problem is that tey don't give enough inforation. or example if I go in Chevrolet > 1994 > G20 > 5.7L V8 > Engine > Harmonic Balancer I find 4 balaner from $29.08 t $109.12 but which is te right one? The same for the water pump and other parts.
Some years ago I ordered a transmission automatric filter but it do not fit in it. I can't risk to buy parts that are wrong because then I can't resend them back.
Do someone of you have all OEM codes parts nr/?
I have the owner manual but I find only codes for air, oil and fuel filters and for spark plugs but not for the rest.
Is there maybe some sources on the web for find these codes?
Thanks
#13
The Dorman 594002 is the stock version. This is also the only of these which refers to an original number #6272222
If you go to gmpartsgiant.com and put in the data for your car they will list **72222 as the original number, now you have a cross-referance, then you can be pretty sure that it will fit.
The other Dorman versions are for upgraded engines.
For transmission filter you need to know which model transmission you have.
#14
Here is the list of what I want change Do you maybe have codes for parts like fuel pump, water pump, time chain with seal, automatic transmission filter and his gasket, belt tensioner, tie rod end (inner & outer), pitman arm, idler arm, brake shoe, wheel cylinder radiator hose (lower & upper), radiator cap.
I beg pardon for the long list ...
After 220.000 km do you suggest change the fuel pump?
#16
About the model of the gearbox I can't check now. Is it write in a label and where?
If you go on the thread of pictures you can see my Van
#18
I don't believe it's a good idea because GM is too big and not a single person or a little factory. I come on this forum for ask advices to other enthusiasts and share my passion for Vans
berekhhnd
November 24th, 2016 3:07 PM
reload69
January 21st, 2011 4:26 AM
