Glue in side window glass
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
Hey..has anybody installed or replaced the glue in side or rear windows on a 2005 or similar express van? I currently have no windows in the barn doors and would like to install one in the front 60% door. What adhesive is used and should I try this myself? Thanks in advance for any help/advice.
Are you sure they are glued in? My factory windows are not glued. I forget how it works at the moment, but there's no glue I believe. All the aftermarket I see are held in with rubber gaskets. At least to my knowledge, I maybe wrong.
The sheet metal work on the factory door is different when made to hold a window. Simply cutting a hole is not good enough. It will flex and break.
It would be better to swap the door out with one purchased from a wrecker. Or contact a body shop.
if the flush look glass wont install in the blank doors by simply cutting out the hole, perhaps a non-flush window would be the answer. CH Laurence is a brand ive come across while surfing. wont look as nice in my opinion.
