grab Reverse (+) for Rear Camera
#21
Well..."someone" doesn't know wtf they are talking about and didn't look at the drawing, there is no other reverse signal on an 03-06 express/savana, the BCM puts out the reverse light power directly. You never mentioned what you are using for a monitor, is it a stereo head unit? Some of the newer ones don't even need this circuit routed to them, they read the class2 data line which also contains gear position so it knows when you are in reverse. If you are going to do this kind of work you need to either go to the gmupffiter website and look up the actual wiring diagram or get a subscription for AllDataDIY for your specific year/model.
#22
... I just want to avoid that I cause an electrical mess and something breaks. As you can imagine, there are not many spare parts in Europe and the import is expensive.
I will follow your advice and pick up the signal there.
P.S .: Unfortunately, the radio can not handle the Class 2 signals, so I have to go this way at all.
#23
So, after German time it is just 15:30 and I had a short time to tap the cable and test it.
What should I say ... You were right. The camera will now turn on automatically and the right input will be selected on the radio. Seems like there is no problem with that.
If you are in Germany, you can drink a beer with me.
Many Thanks!
Many Thanks!
#24
Many Thanks!
Many Thanks!
#25
Well..."someone" doesn't know wtf they are talking about and didn't look at the drawing,.... .....If you are going to do this kind of work you need to either go to the gmupffiter website and look up the actual wiring diagram or get a subscription for AllDataDIY for your specific year/model.
Ponyriemen
I am glad you got it done too.
