Help, break light on after replacing front pads
Old Oct 10, 2019 | 9:03 PM
Edward Fraker's Avatar
Default Help, break light on after replacing front pads
Hello, I have a 2007 Chevy Express 1500. I replaced the front pads today and now the break light is on. I have done all I know to do which is double check and make sure the emergency brake is off and topped off the fluid in the reservoir. What else could be the culprit? I have heard about a million ideas. What is the most common thing that could go wrong? And FYI. I used a C- clamp on the calipers. I have done this a thousand times and never had an issue.
Thanks for your input in advance.
Old Oct 10, 2019 | 11:59 PM
damaged wheel speed sensors?
You really just need to scan the OBD codes.
Old Oct 11, 2019 | 8:48 AM
toolhore's Avatar
Turn your ignition switch to the on position, then immediately depress the accelerator pedal 3 times. Thats how I corrected mine
Old Oct 12, 2019 | 6:49 AM
toolhore's Avatar
I should have asked this first. When You say brake light, which one are You referring to, the dashboard light or your exterior rear brake lights?
RickR90s
2007 - 2013 (GMT900)
Feb 21, 2018 12:34 PM
dab7547
Feb 15, 2017 11:16 PM
Mille Racer 69
May 19, 2012 7:27 PM
Redwire
Nov 10, 2009 7:29 PM
jonathanlyford
Apr 16, 2009 9:18 AM
