HVAC Controls Backlighting - Solved
Old Mar 3, 2024 | 5:50 PM
VanKo's Avatar
Default HVAC Controls Backlighting - Solved
I've seen this issue pop up a few times here and have been dealing with it myself. Finally found a resolution that doesn't involve buying a new module or getting one from the junkyard with possibly bad bulbs.
The backlighting in my 2013 Express HVAC controls went dim, then died altogether. There are two bulbs, one died and the other followed. These bulbs are both made by JKL Components. They can be sourced though various electronics suppliers but MOQ applies and I wasn't going to buy 20-100 of each. Finally narrowed my search down and was able to find equal versions of each bulb. Just changed them out and everything is good. Total cost was $17 and took me 10 minutes to change the bulbs. Totally worth it to having working backlighting again.
Bulb 1 - Right side of controls, behind mode selector ****:
Original - JKL DNW1-DW10/GRA/22MM https://www.jkllamps.com/automotive/...-DW10_GRA_22MM
New - CEC 8640 https://www.cecindustries.com/produc...ntPartNum=8640 (Found on eBay, $9 for a box of 10 bulbs)
Bulb 2 - Left side of controls, behind fan speed selector ****:
Original - JKL FWG-103 obsolete
New - Sylvania 2723 https://www.sylvania-automotive.com/...723LL.BP2.html (Found at Advance, $7.49 for a 2-pack)
Specs (wattage/MSCP/lumens) are extremely close if not exact on both bulbs. The new bulbs are a bit smaller physically which is not an issue. Now installed, they match the rest of the interior backlighting.
Old Mar 3, 2024 | 7:41 PM
Rednucleus's Avatar
Good job - I have several of those in my 93 Suburban control - AND they are all overdue for replacement!!
Old Mar 3, 2024 | 7:55 PM
VanKo's Avatar
I had gotten so used to the burn out bulbs - now it looks so different. I have two power window switches to do next.
Old Mar 19, 2026 | 10:38 PM
Expresscv's Avatar
Thank you so much for taking the time to write all this up!
Little Jimmy
11
Apr 2, 2023 7:51 AM
Spencer D.
Feb 15, 2017 10:26 AM
trx680
Aug 8, 2016 8:15 AM
northey87
Feb 13, 2008 11:51 PM
