installing a window in cargo van . . .
Old April 9th, 2023, 11:47 AM
Rod E's Avatar
Default installing a window in cargo van . . .
Looking to put a window in my 2017, 2500 Express cargo van, passenger side; rear of side doors. Can't find a source for the window with frame. Any ideas?
Old April 13th, 2023, 4:52 AM
HvyChvyG20's Avatar
Where are you located?
Try contacting Kurk Collis at Customvan.com 1-800-495-VANS. He's in PA.
Old April 13th, 2023, 9:17 AM
Rod E's Avatar
Thanks, I "ll give him a look. I'm on the other coast, Oregon, but I'm striking out for help out here.
Old April 13th, 2023, 9:33 AM
Rod E's Avatar
Default Body curvature the same?? Cargo vs Passenger
So having chewed this window add on for some time I'm seeing the question more clearly . . . Do Chevy cargo vans have the same body shape as passenger vans?
If so I'll just buy a passenger van window for that quarter and drop it in.
The kicker is, is that body curvature the same?
Who would know?
Old April 13th, 2023, 11:56 AM
I'm pretty sure there's additional support structure for the glass.
Old April 17th, 2023, 12:52 PM
Rod E's Avatar
Ok, I’ve found and obtained the window (see pics.). At the wreckers I got it off a Chevy 3500 passenger van. So . . . ! Do you think you think someone (who?!) can make it work on our 2500 cargo van? The measurements match up perfectly. Just not sure how the window attaches to the frame.
Old April 17th, 2023, 1:49 PM
The window is glued in
Like I said before, your van does not have a support structure that passenger models have. It's missing a horizontal beam. Maybe you should do more research before continuing down this path. If your body panel flexes too much the window will shatter. A 1x4 piece of wood isn't going to do squat.
Old April 17th, 2023, 1:51 PM
Rod E's Avatar
I realize I may have to have a "support" structure built.
Old April 23rd, 2023, 8:52 PM
loopedr1's Avatar
the real problem you will have is 1...that glass had delam of the frit band and needs to be preped correctly....2...where yo want to install it is not like a personal van...it will stick away from the vehicle a little more than normal.....other than that no problem...
Old April 23rd, 2023, 10:19 PM
Rod E's Avatar
Thanks! I’ve got a good installer lined up. Praying it goes ok!
Quick Reply: installing a window in cargo van . . .
