instrument cluster bulbs
I have my cluster out from my dash removal on my '92 Vandura and thought I'd replace the bulbs. Ran down to my local Canadian Tire and purchased 194 bulbs. When I tried pulling out an old bulb the wires were wrapped around the outside of the base. Best described as those mini Christmas light bulbs. Typical 194's won't work like that. I cut the wire and McGuyver'd one in the base. Now it won't even come on. I noticed the watts aren't identical as the manual says but I thought this would work. I'm on my way to an auto parts store to see what they have. The bulbs I need are L1 PC194 2watt and PC 168 3 watt which actually has "replace entire ASM" stamped on it.....didn't know bulbs changed so much in 1992.
Ya, no kidding. The auto parts store was a little confused to but ended up having them. For about $2 a bulb I have too many other things on the go to start soldering but thanks for sharing!
Tanin Auto Electronix Speedometer Repair, Odometer Correction, LED Customization, and DIY Parts
Let us know if you have any questions and we will be happy to assist you on this.
Thanks,
