Master cylinder or Vacuum booster
Old August 4th, 2013, 12:34 AM
  #11
200OZ's Avatar
Uh.... yup, your right on that one.
So Jason.... any news on your brake issue?
Old August 4th, 2013, 11:53 AM
  #12
when driving, if you pump the pedal does it firm up at all or remain low?
Old August 5th, 2013, 12:24 PM
  #13
jasonthatsme's Avatar
Originally Posted by tech2
metering valves are not needed on a 4 disc brake system. their sole purpose is to delay the front calipers from applying until the rear drum return spring tension is overcome. you are confusing a proportioning valve with a metering valve.
I don't have a four disc system. Drums on rear.
Old August 5th, 2013, 12:26 PM
  #14
I ordered a new master cylinder and brake lines all around. They will be here tomorrow. I'll let you guys know if this fixes the problem. Thanks
Old August 5th, 2013, 12:27 PM
  #15
It does seem to firm up a little but nothing like it should be.
Old August 6th, 2013, 7:24 AM
  #16
if you apply and hold the brake, does the the pedal slowly sink to the floor? If yes, have someone watch the fluid level in the reservoir, does the volume of fluid rise in the m/c? Both are signs of an internal fault in the m/c.
jason78
April 13th, 2014 2:40 PM
qzack1
August 28th, 2011 12:50 PM
aussie chevyguy
December 8th, 2010 7:00 AM
Donald91
August 9th, 2010 9:53 AM
randys94
May 14th, 2009 9:39 PM
Quick Reply: Master cylinder or Vacuum booster
