Motor Oil Lines?
Motor Oil Lines?
5.7 Litre, has oil lines coming off the RH side of the engine, going to an oil cooler? Haven't had any trouble with them until now, I've developed oil leaks, after parking the van for a little over a year. Can anyone tell me more about this cooler? My mechanic has gone away, so I'm on my own.
Yes, depending on model van, you will have an oil cooler. Those lines are known for leaking. I believe they connect to the radiator.. the oil cooler is part of the radiator.
Only thing worse is the hydroboost lines. Those buggers leak like crazy, and new ones don't last long.....look for oil pooling on the bcm module under the master cylinder.
Are you using high mileage oil? The higher zddp may help with small leaks like that....
This is a common problem? Do you know how long it takes to develop on a new van? Is there anything a person can do to prevent or prolong it? I despise leaking vehicles. It's been a very long time since I've had to deal with that.
PS I have an oil cooler and I believe an transmission cooler as well. I'd have to look, I remember something was different on this one from the last, but there are coolers there.
You have nothing to worry about db. It was a common thing on the 5.7 and 6.5, and only once they got older. (We do have oil and trans coolers.)
I have a link saved somewhere showing a guy who got tired of replacing his oil lines and had a tractor/backhoe hydraulic hose shop make him up some new ones and then using union fittings etc to simply replace the Genuine GM Garbage oil lines. This seems to be another of those parts that were simply 'cheaped out' at the factory.
I've had to do mine twice... replaced leaking oil lines once with GenYuWhine GM parts (as part of the 3.5 engine rebuild) and then, six months later with parts that would last a tad longer... (Dorman).
Guess which oil lines have a lifetime warranty and which ones don't. Yeah... it ain't those factory parts.
I can't find the link but if you remove both your lines AND the fittings at the radiator and engine (where OEM lines clip into) with you to a hydraulic hose shop they can set you up. (You'll need a union fitting and threaded fittings to use the hydraulic hose fittings.)
Or... just found this looking for the other one... Link to "cheap fix": Repair your leaky oil cooler lines!! - S-SeriesForum.com
GoldToyBox
September 5th, 2011 11:59 AM
GoldToyBox
September 5th, 2011 11:47 AM
