Need help removing the dash
Im trying to swap out the stereo in my Chevy Express boxvan/truck
but I cant seem to get the dash out because its one piece and both the shifter and the turn signal go through the hole.
Can someone tell me or show me how to remove the dash?
Thanks
Thanks
My haynes repair manual goes from 96 to 2007. You should check to see if there is an edition that covers your 2010. They are great for things like this.
I know your interior is different than mine, so all I can suggest if you don't have the book, is to feel around for what is held in with those spring clips. Once you pop out a few panles you will find the hidden nuts and screws that you can remove.
Google "Chevrolet Express Dash Removal" and you will find instructions.
In general you remove the driver's knee bolster, the passenger's knee bolster and then the instrument panel cluster trim panel. The two knee bolsters have a couple of panel screws each you have to remove.
I tried googling and there isn't much info out there and what I saw was different in a couple places.
How do I get the dash around both the shifter and the turn signal?
Roy183
August 15th, 2013 11:00 AM
