New Member, Many problems!
Old December 18th, 2012, 4:49 PM
  #11
HOMESLICERYRY's Avatar
ok, Will have to look into that. I believe its going to be something stupid its just a matter of finding it!
Old December 29th, 2012, 7:53 PM
  #12
Welp the time has opened up and its going into the shop, hes thinking timing chain possibly. We will see
Old December 30th, 2012, 12:12 AM
  #13
tsbrewers's Avatar
let us know how it goes.
Old January 6th, 2013, 2:18 AM
  #14
Timing chain had skipped 2 teeth, work is in progress! Doing the whole nine, whatevers recommended during this job is getting done, water pump as well. Cant wait!
Old January 20th, 2013, 6:45 PM
  #15
Update, van is running great. Also found a frayed wire off the harness he took care of and has been running like a top since
Old January 20th, 2013, 7:10 PM
  #16
tsbrewers's Avatar
good, thanks for letting us know what it was and that it is fixed. That always helps in the future.
Brew
Old January 21st, 2013, 6:18 PM
  #17
Just to add a little further, the wire was actually rubbing against a stud on the motor and frayed, right side of the motor near the exhaust manifold. 200k no complaints! Was actually offered 2800 by his Landlord, but his advice was to keep it the truck should be running great for a long time to come!
Old January 21st, 2013, 8:14 PM
  #18
tsbrewers's Avatar
I have bought a few vans from the car auctions and have looked at thousands to find the few I bought. There are TONS that are well in to the 300k's that are still running around. 200k should have a lot of miles left.
Old April 27th, 2015, 11:06 PM
  #19
Mash's Avatar
Default alarm not letting truck start
My 1995 Chevy 1500 truck stock alarm will not let it start. Already checked battery and connections. Alarm has switch, clicker and button. Already tried different combinations between them.
Old April 28th, 2015, 11:38 PM
  #20
canucklehead's Avatar
Doubtful that it is a stock alarm. It is likely an aftermarket one that has failed....
You may have to rip it out.
If it has an ignition interrupt, then you have to bypass that.
Or, with key in on position you can prob jump to the starter to get it going....
Quick Reply: New Member, Many problems!
