No Crank No Nothing 99 Express 1500
Hey guys I bought this van about a month ago, been working on turning it into a camper van. There was an old power inverter that I removed and while removing the positive cable that goes back to the battery, it made contact with the metal floor. It arced and I grabbed it as soon as I could but it was too late. Now the van won't crank, start, no lights, no interior controls, nothing.
The starter relay has no voltage to it. I pulled it and tested the 4 terminals with the key in the on position, nothing. I can turn the key to the on position and bump the starter with a screw driver and it just cranks and cranks but will not run. All fuses in the cab and relays/fuses under the hood look good.
Someone please help I'm out of ideas! Thanks!
Can you explain what you mean by fuse link? Or where it's located so I can troubleshoot it? As far as I can tell all fuses and relays are still good. Both inside the cab and under the hood. Thanks!
