NO SPARK. Please help
Hello everyone! I'm new here so please excuse any errors etc. Looking for some much needed input because I'm about ready to pull my hair out......I have a 2003 Express with 4.8L V8 and I have no spark, this is what i've done so far.
Replaced Plugs and wires
Replaced Crankshaft Position Sensor
I was preparing to go get new Catalytic Converter the day it decided to not start.
She turns over but no fire(of course given no spark)
Can anyone suggest where the next step is??
The issue I have is getting it anywhere to get a code reader on it but thought I'd try to rule out some of the starting points etc........
I'm going crazy but any info would be appreciated! Thanks in advance.<SCRIPT language=javascript type=text/javascript>//<![CDATA[var ret = YAHOO.forumsSMOLinks.genlinks("all", "http://townhall-talk.edmunds.com/direct/view/.f0fb7ac/67", document.title, "post");if (ret) { document.write(ret);}//]]></SCRIPT>
I was having the same trouble. I went and bought a spark checker at Harbor Freight they probably have these at most auto parts stores. It plugs into a plug
wire like a spark plug and the other end plugs into the plug of the cylinder that you are checking.
So when you crank the motor the spark checker blinks when that cylinder is supposed to fire. No blink means no spark. Have the coil checked or buy a new one if there is still no spark.Check all connections as well
before you throw the kitchen sink at the car, did you check the ignition control module? No ICM, no spark. The ICM sends the signal to the coils to fire. If its out of order then you will never get a spark.
stdhawaii60
December 24th, 2010 11:14 AM
catill
August 30th, 2010 11:07 AM
