Awesome, will be looking for that box. (Maybe the antique mall will be interested) Considering the damage to the rack from a previous owner, wasn't planning on roof mount. Sacrificing a bit of distance to keep the antenna safe with a mirror/body mount was the idea. Didn't think of/hadn't seen anything regarding the fibreglass roof though, thank you. Didn't think a magnet would hold very well up there anyways.The ground plane (if it's where I found the two leads) are screwed into the "original" roof underside. Donald didn't take the whole roof off before capping, just cut a hole starting/ending about 3' from front/back ends.
Agreed and thank you again. Just worried the mirror mount won't "fit" the stock mirror quite right. Would the ladder on the back maybe work just as well? Otherwise was thinking maybe the gutter along the side.
Planned package with a Sharp model 500 UB left in my care by the Oscar the grouch at work. Said he never tuned it and for him it only worked near water. I was surprised it didn't blow out on him.
That's an old one. I haven't been in to CBs for quite a long time, but I Googled it. Having an SWR meter is handy, but tuning an antenna of that style may be difficult, so I hope it is good from the start.
I see without the tip requires cutting the wire so it's kind of like woodshop all over again. Measure twice, cut once, and check fit. Repeat until satisfied. Go too far and have to start over. Thank you again, think I'll go with tunable firestick.
If the SWR on channel 40 is greater than that on channel 1, your antenna is considered to be "LONG" and reduction of physical height and/or conductor length will correct this situation. Depending upon antenna model, this entails screwing down the tunable tip (Illustration #1: Firestik II, Firefly), or, removing the tip, making short slits in the plastic covering and unwinding and clipping off wire (Illustration #2: Firestik, Road Pal). Firestik Designer Series antennas require loosening the allen screws and lowering the metal whip (Illustration #3).
ADJUSTING SHORT ANTENNAS
If SWR on channel 1 is greater than that on channel 40, your antenna is considered to be "SHORT" and increasing the physical and/or electrical length of the antenna is required to correct this situation. Because we make our antennas extra long, readings which indicate "Short" normally stem from ground plane deficiency (lack of vehicle metal surface for the antenna to reflect its signal rom). This condition is often corrected by adding a spring and/or quick disconnect to increase the physical height. Ground plane deficiencies can also be compensated for by using dual (co-phased) antennas or special no-ground-plane antenna kits.
Lengthening of the Firestik II and Firefly is accomplished by turning the tuning screw further out (Illustration #1). On Firestik and Road Pal models, it requires tip removal, short slits in the plastic covering and, the separation and upward repositioning of three or more wire turns (Illustration #4). Firestik Designer Series antennas require loosening the allen screws and raising the metal whip (Illustration #3).
NOTE: The shorter the antenna, the more sensitive it is to adjustments. For example, removing two wire turns on a 4 foot antenna might move the SWR by 0.3; the same amount removed from a 2 foot antenna may move the SWR by 1.0. Make smaller adjustments on shorter antennas."
