P0420/P0430 OBD code - what a bad catalytic converter looks like
Old Sep 8, 2013 | 12:35 AM
CableSux's Avatar
Default P0420/P0430 OBD code - what a bad catalytic converter looks like
No question, just thought I'd share a little info that might help others with codes P0420/P0430. Often I see people asking if the O2 sensors are bad or the catalytic converter. Since I use the ScanTool and software to graph the O2 sensor voltage levels, I think it's safe to see, in my case, that the bank 2 (right side) catalytic converter is toast.
Bad cat Bank 2 (right/passenger side) - notice the signals are nearly the same both pre (sensor 1) and post-cat (sensor 2), meaning, the cat isn't doing anything.
Good cat (bank 1 left/drivers side) - The pre/post cat signals are very different.
If I'm wrong, please let me know and I'll correct this post. I would hate to have a reference with bad information.
I'm using the OBD Wiz software
ScanTool.net LLC - OBDwiz Automotive Diagnostic Software
that came with my cheapo OBD interface.
OBDLink SX Scan Tool USB Interface w/ OBDwiz Diagnostic Software
on my little Gateway notebook. Well worth the $49!
Old Sep 8, 2013 | 9:41 AM
That is nice info to see...
What version of the software are you using?
Old Sep 8, 2013 | 12:28 PM
MDTAHOE's Avatar
Professional Mechanic
You are correct. If upstream and downstream voltages mirror each other the cat is not working thus po420 or po430
Old Sep 8, 2013 | 1:45 PM
CableSux's Avatar
2.15.1.738 Think they can add a few more numbers?
Old Sep 8, 2013 | 2:27 PM
My bad, are you using the one that comes with the OBDLink SX Scan Tool, the Scan XL standard or the Pro....
Old Sep 8, 2013 | 11:21 PM
CableSux's Avatar
Correct, it came with the SX. Actually, I think the version that came with it was older and I downloaded the latest version at
http://www.obdsoftware.net/obdwiz.aspx
Old Sep 9, 2013 | 4:21 PM
HOMESLICERYRY's Avatar
Code p0420 and p0404 just swapped in a new cat, no more codes
Old Sep 9, 2013 | 4:40 PM
thanks for the follow up!
Old Sep 18, 2013 | 9:05 AM
gilstone's Avatar
FYI - Just had to replace my catalytic converter, vent valve, sub harness and O2 sensory on my 2007 Suburban with 84k miles...a $1,230 job. I missed the gov emissions warranty by 4k miles.
Old May 20, 2016 | 2:07 PM
4x4tx's Avatar
Will these codes cause the reduced engine power messages? I just had my throttle position sensor replaced and I am still getting this code....supposedly they cleaned the throttle body while replacing the sensor.
