parasitic draw - Retained Accessory Power - draw on battery with ignition off?
#11
#13
I have a parasitic draw on my battery.
I found it going thru fuse 51. I can only find that fuse 51 feeds the HIGH speed of the blower.
I did a desk top continuity test of BMRA and do not see anything I identify as a short. (?)
See Image Below.
I assume that to have a parasitic draw thru the BMRA it would have to have a short in it feeding power to ground.
Anyone see what I am missing?
Could this mean there is a short in the r/blk wire from fuse 51 to the wide connector?
Since the blower motor is feed by the BMRA could it short without the BMRA? ... clutching at straws
See Image Below.
#14
I have a parasitic drain on my 1988 G20 van I still can't figure out.I've pulled all of the fuses and put a test light between the positive cable and the positive post and it still lights up.
#15
how much is the draw? Use a amp meter instead of the test light. anything over 50mamps is excessive. What aftermarket items are wired into the van. Aftermarket remote start modules can add 30mamps.
