Regular Production Codes
Funny. My door sticker says I have AK5.
Yet, I do not actually have AK5.
At least I do not have any of the electrical connections that AK5 seems to list. Maybe because I have C99, half of AK5 's wiring gets deleted.
I want this below, even if I never actually end up using it:
If anyone has it installed and operating in their truck as per factory, I would love to know more details. Is there a switch? Is it just a BCM update? Etc.
UF3 High idle switch 1 - Requires (L96) Vortec 6.0L V8 SFI FlexFuel engine and (ZQ3) Convenience Package. 2 - Requires (L96) Vortec 6.0L V8 SFI FlexFuel engine and (ZQ3) Convenience Package. Included with (YF2) Ambulance Package.
You don't have frontal air bags?
I found the information here: https://dan.berladyn.online/gm/uf3-fast-idle/
You can add it, it will just cost you $$. Please do it and let us know how much.
Yes frontal airbags, but that's not what AK5 lists as. I think because I have option C99 it cancels AK5 out. At least the full version of AK5. As per the schematics on this page. I grey out the options that I do not have for easier reference.
https://dan.berladyn.online/gm/seatb...traint-system/
PS. That link also has information on your blinking light you were telling me about.
Yeah, AK5 seems to be :
Air bags, frontal, driver and right-front passenger
1 - Includes passenger-side air bag deactivation switch.
Always use safety belts and child restraints. Children are
safer when properly secured in a rear seat in the
appropriate child restraint. See the Owner's Manual for
more information.
So, what is it that you think that is, Dan?
more information.
- RESTRAINT SYSTEM – SEAT, INFLATABLE, DRIVER AND PASS FRT
From other sources people have stated it simply means airbags. If you look at the actual schematics, it seems to have more to do with seatbelts, indicators and pretensioners than the actual airbags. Of course that's just my interpretation. AK5 probably means Airbags and AK0/C99, depending which you have, likely changes that AK5 build option.
I posted that right when you were posting #6. Oops.
So, in thinking about it, I'm thinking of getting a junkyard throttle pedal assy, and wiring it in with a switch. These days it's all control by wire, and while I haven't looked, it's likely only two conductors into the data bus. I don't have it in me today, but I'll look into it soon.
dberladyn (July 28th, 2019)
I could go to the trouble of using a relay, in conjunction with either the parking brake or neutral/park signal lines. Unless those are on the data bus, which seems unlikely, since those are at the radio, for video purposes.
