Replace bad engine with GM or Jasper or ...?
Old March 9th, 2014, 11:18 PM
Johnny Crab's Avatar
Default Replace bad engine with GM or Jasper or ...?
Our white 2000 Express 1500 conversion 5.0 engine finally gave up the ghost today but fortunately it was leaving the house and was able to be driven home. The engine has about 272K miles and, thanks to Mobil 1, has SURVIVED this long with two major stresses thanks to Mobil 1 IMO:
1) Had the gasket leak antifreeze into the oil at about 170k, replaced gasket
2) PLASTIC radiator drain plug cracked, dumped coolant, drove 1 mile redlined heat at 200K(had to drive off of a bridge, no shoulder).
So it was tired.
We LOVE this van(nicknamed White Workhorse), have had it since it had 30K miles, and it is set up to tow(has towed a bit moving children to and from college and around Texas). Trans is still good and can be "made as new" by a shop that has done a number of co-workers' trucks(that is already budgeted for).
Questions:
Should we replace the engine with a new GM 5.0(~$1700~1900 + labor), a Jasper, or have the best local shop rebuild it?
What sort of costs, besides the engine, should we expect with labor + misc parts(sensors, etc)?
Thanks,
JC
Our budget is about $5K and we do NOT want a new vehicle note and could not afford a new(or almost new) van.
Old March 10th, 2014, 12:05 AM
the_engineers's Avatar
A little more power...
http://www.summitracing.com/parts/na...make/chevrolet
Old March 10th, 2014, 10:03 AM
93ChevyVan's Avatar
I would switch to a 5.7L engine with 260HP for your towing needs. It is my understanding that they are the same size as the 5.0L (what I have too) and can simply plug n play to the transmission. I plan to do this switch if my 5.0L ever fails. Not sure which way to go yet (rebuild, Jasper, GM Goodwrench, etc. . )
Old March 10th, 2014, 10:08 AM
canucklehead's Avatar
Pick up a vortec 350 from a wrecker....you may find one that is only halfway through its lifespan.
Old March 10th, 2014, 7:17 PM
greenfire's Avatar
Id buy whatever one gives you the best and longest warranty.
Old March 12th, 2014, 1:23 PM
tucker442's Avatar
I've installed both and like the Jasper deal with the hose and belt kit. I am a 35 year GM Dealer A Tech and have seen a bunch so if the money is the same I think Jasper has a better warranty but check it out first.
Old March 12th, 2014, 5:00 PM
Thanks all.
There are 3 folks competing for the work: local GM dealer, local shop we've used for 25 years, and the shop that did the intake manifold gasket work(when no one else would do it when we said "conversion van").
So far, the GM dealer quote is $6600.
Manifold gasket shop needed the VIN and will quote GM engine & Jasper. Their estimator said they do a lot of business with Jasper. I'll post the other quotes when they come in.
Local shop looked like they had a lot of work so he may be a few days.
Old March 26th, 2014, 9:46 PM
rags_the_dog's Avatar
Powertrain products inc is best for warrarty on engine they offer 4 year and 1 million warranty national and no fault warrarnty $299 than jasper..
but just want y know.. here link
Power Train Products Factory Tour-rebuilding engines, transmission, differentials, transfer cases and cylinder heads.
Old March 27th, 2014, 2:37 AM
New User
Awaiting E-mail Confirmation
moparchevy's Avatar
I would go with jegs but that is just me.
Old March 27th, 2014, 2:39 AM
New User
moparchevy's Avatar
This is a good option
Originally Posted by the_engineers
Quick Reply: Replace bad engine with GM or Jasper or ...?
