Retrofitting back up sensors
there seem to be a few not in use wires with plugs at the back of my van
reading on various threads i see references to wiring for backup sensors
has anyone added the stock sensor kit to this wiring? Or know how to do it?
mine has the camera but i am leaning toward sensors also
Can you post photos of the wires?
my wires are covered up now, but there were quite a few of them back there
i have a feeling the wiring is there to do it
turned out i had an old back up sensor step that goes into the trailer hitch and bluetooths to a little 12 volt beeper, i am going to use that for the summer once i drop the trailer and pull the wd hitch
may end up adding an aftermarket back up sensor set in the fall
one thing i did add is the loud back up beepers from e trailer that are inside the rear back up lights, pretty easy to switch out and they seem to work pretty good
