Searching a programmer for my 2014 express?
Hello people,
What programmer is right for me and my car?
I have a 2014 express with 6.0 engine.
specifically I'm looking for a programmer with which I can change the shiftpoints of the transmission.
many programmer is described: shiftpoints changeable
This means only in the kick down mode (max. RPM) or even if I drive slow (Cruisin' mode).
during the crusin, the transmission should shift 200 - 500 RPM earlier.
for example: the shiftpoint from 5-6 gear at 2000 RPM,... that is too high.
and if the engine cold are the shiftpoints over 1700 RPM, also too high
which programmer can this change?
troublecode read and delete he should also can.
the programmer must always be installed?
or I can after set in and read out him remove.
thank you.
I was there looking for and all other manufacturers.
but. I see that correctly?
all edge show only values and data but no change of the software possible (particularly transmission).
Superchips and hypertech have told off already.
the software supports only pick up but not van. is too different.
I'm still waiting on the other producers.
Unfortunately, the bulldog gt 40410 (40417) is apparently the only one who works.
I know on the pickups black bear performance makes the best tuners, I called them about tuning mine and they wanna send me a mapping/storage device to base the tune off of, seeing as they've never tuned a van
